Steering Wheel Shudder
  • aaron_silva
    • 1785
    When I am driving at highway speeds and touch the brakes and when I am under hard braking, my steering wheel makes this noise (not really knocking but a shaking "knocking" noise). Does this have to do with brake components or steering?
    Thanks
  • RedBaron86325
    • 386
    Mine is currently doing this too. I have narrowed "my" problem to the control arm bushings. M3 rubber offset control arm bushes are in the mail (Ireland Engineering).
    Don't forget the good things Hitler did.
    • aaron_silva
      • 1785
      Thanks for the info. Let me know if this fixes the problem.
      Thanks
      • UNHCLL
        • 8789
        if its only when you hit the brakes, then you may have warped your rotors.
        Chris
        Below the radar...
        • aaron_silva
          • 1785
          It is not only when I hit the brakes. For example, when I was driving on a cobble stone street, it made the sound the entire time, every bump.
          Thanks
          • UNHCLL
            • 8789
            Tie Rods, Control Arms, Control Arm bushings.... those are all possible
            Below the radar...
            • aaron_silva
              • 1785
              Thanks.
              • e30evolution
                West Werks
                • 1888
                could be the steering column... mine is loose and makes a clunking noise when i go ocer bumps and stuff.... it doesnt really shake tho..... you could check by taking off the three screws holding the knee guard on and an 8mm nut driver to take off the 4 on the bottom... grab the steering column and try to move it.... see how much play it has, and if it makes a clunking noise
                http://www.westwerksauto.com
