aww ok
Low on Power (obd1 m52)
Need some new ideas.
Car still is shitty for power. Getting 13 mpg. I hate everything lol
I will be cutting the wiring to my o2 next to see if anything changes since its spliced in. If not....idk what to do next except for a new harness.Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
I was gonna take mine into the shop, but the guy there said I need to get the O2 sensor to where it is reading from all cylinders. Right now the stock exhaust manifolds are being using and the O2 sensor is plugged into the front one. So I dont have the reading of the back 3 exhausts ports.
So need to do that then I can take it to them to see what's up.1990 325is
m52b28
3.73lsd
g260 (1987 325is 5spd tranny)
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
Vacuum test completed yesterday, everything seemed correct which would indicate no exhaust restriction, and i believe no vacuum leaks.
car has its good days and bad days.
when I drive with the maf unplugged, does it go into the same open-loop as if I unplugged my o2 sensor?Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
i know everyone is sick of seeing this thread popping up....but just throw random shit out there. ill try it at this point. im getting close to bringing it to a shop lol.
Things i havent tried but plan on trying as soon as weather cooperates :
disconnecting o2
replacing vanos seals (i know this would give bad mpg, but cutting mpg in half? seems excessive)
new engine harness (might go obd2 at that point)Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
So back during winter when it was cold and minnesota was using their less efficient winter gas, I was going about 120 miles max off 9 gallons of gas. (13.3 mpg)
Now that summer gas is back, I am back up to 180 miles on 8.5 gallons of gas. (21.1 mpg)
I'm still having power issues down low, so I plan to do vanos seals next. But I find it odd how just having warmer weather and better gas improved my mpg by that much.Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3
