Steering column controls alignment
  • bobdavisnpf
    • Apr 2017
    • 56
    How do I adjust the alignment of the steering column controls?
    Yesterday I replaced the turn signal switch on my '89 325i vert, high beams are working again - yay and thank you to awdbob for the good part.
    The steering wheel nut unfortunately was too tight for me to get it loose with a socket wrench; in my rather finite wisdom I opted for the $35 pneumatic wrench vs the $99 manual torque wrench to increase my "power of persuasion". It did the job with little difficulty, but now the steering column controls are all tilted counterclockwise a couple degrees.
  • superj
    • Feb 2006
    • 397
    wow, I guess you will just have to try and apply a certain amount of torque in the opposite direction to rotate it back
    • Mwishlist
      • Jul 2013
      • 505
      I am pretty sure there is a non-reusable bolt that holds the controls to the column. If they break loose you have to drill it out and use a new bolt or find another way to snug everything back up.
      Basically, you shouldn't leave the steering wheel locked while removing the steering wheel bolt.
      Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
      • bobdavisnpf
        • Apr 2017
        • 56
        Yes, the Bentley manual describes a shear bolt holding a collar clamp at the floor. I think it also describes the need to keep the steering wheel unlocked and just hold the wheel when loosening the nut. My fault for using online and youtube info, and failing to read up on the procedure in the Bentley beforehand.
        • superj
          • Feb 2006
          • 397
          Its ok. I use the lock sometimes also
          • MR E30 325is
            • Dec 2008
            • 3300
            I use the lock to secure the steering wheel almost every time.
            But if the nut is super tight that is a different story.
            My previous build (currently E30-less)
            http://www.r3vlimited.com/board/showthread.php?t=170390
            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
