flooded engine
  • E30godz
    • 1524
    flooded engine
    with the install of the bigass injectors, i have flooded the engine a bit. I havent been able to get the car to crank in 2 days now and am getting desperate. can i remove the spark plugs and the fuel pump relay and crank the car to remove any fuel sitting in the cylinders?
  • Jordan
    • 12916
    just remove the plugs and let it air itself out....
    you have to be retardedly flooded to not be able to start for that long.
    https://mtechniqueabs.com/
    • onenicebimmer
      • 139
      You can also clean off the tips of the spark plugs with some 600 sand paper.
      • E30godz
        • 1524
        it worked it self out somehow...yes 30lb injectors will retardly flood an engine when your just guessing at how much fuel to dial back.
        • Charlie
          kid tested, administrator approved
          • 6686
          Why in god's name were you running 30# injectors on a motor making 4 lbs of boost?
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
