Help Identify Vacuum Line
  • d0l3m1k3
    • 17
    I need to know what this hose is, what what the part number is... I can't seem to find it on RealOEM.
    Anyone have any ideas? I'm lost here.
    It connected to the throttle body or the intake manifold on my 87 325is.
  • NC325iC
    • Mar 2004
    • 6565
    charcoal canister valve hose i believe
    • d0l3m1k3
      • 17
      Awesome, that's what I thought too. I can't find it to order though
      • blazing
        • 274
        I replaced mine with regular vaccum hose.
        I just took the valve to the parts store and matched it up.
        • cthulu703
          • Oct 2004
          • 288
          Is there a carb on that thing?
          • d0l3m1k3
            • 17
            Rofls. No.
            I went to the junkyard yesterday. All they have are e30's with small throttle body, so no luck on this hose. I dont see how I could replace it with regular vacuum line.
            • arsevader
              • May 2005
              • 1025
              I beleive you need part # 13 31 1 288 284
              • RobertK
                Kicked cancer's ASS.
                • Jun 2005
                • 5864
                You can use an ordinary vaccum hose. You don't have to use that once specifically. When mine went bad I just cut a piece of vaccum line and replaced it with that. No problems.
                All the top part of the OEM hose does is go around the end of the plastic.
