I'm putting my intake back on and I routed my loom in and noticed that the silver sharpie marks I made aren't visible cause my GF cleaned them to well:curse: while I had the intake off. I only have one of my original stickers still in tacked on my number 6 injector wire. How do I determine what wire goes where??
Injector wire question
Whether you have the e engine or the i engine the following holds true:
The ECU fires a bank of 3 injectors (1-3-5 or 2-4-6) at the same time. There is a common power conductor to all 6 injectors, it's the red/white wire. The ground signal from the ECU is on the brown/white wire for the 1-3-5 bank and on the brown/yellow wire for the 2-4-6 bank. -
Perfect thank you Sir :bow:
Dave
The ECU fires a bank of 3 injectors (1-3-5 or 2-4-6) at the same time. There is a common power conductor to all 6 injectors, it's the red/white wire. The ground signal from the ECU is on the brown/white wire for the 1-3-5 bank and on the brown/yellow wire for the 2-4-6 bank.Comment
