Differential Oiil
  • MikesJo
    • Mar 2004
    • 989
    Differential Oiil
    My differential has a small leak, not bad enough for me to see oil on the ground but it is wet. I might not change the seals asap but was wondering should I top up my differential fluid or just totally flush it and put in new fluid? I havn't done it since owning the car and I don't know when the last time the PO did it. I've had the car for 7 months I think.
    I do hear whinning from the rear when I accelerate and are at higher speeds, so I'm thinking I do have to put more fluid in the differential. Just wondering if I should top it up or change it entirely, ie. flush it out.
    Vancouver Portrait Photographer
    E30 M3 Wallpapers
  • lordofthewaters
    • Oct 2005
    • 714
    Check it to see if there's enough in there. If there isn't and it looks clear then I'd just top it off since it's leaking anyway, if it looks dark or dirty drain it and refill. Of course that's if you're not going to fix the leak right away....................
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • robsgotit
      • 550
      what wieght is recommended? ive got to do mine soon and im curious, ive got a 2.93(8)? lsd.
      Delrin shift knobs for sale and trade
      http://www.r3vlimited.com/board/showthread.php?t=196156
      • lordofthewaters
        • Oct 2005
        • 714
        Sae 90 GL-5
        • Jparkr
          HR Admin
          • Jan 2006
          • 3494
          I use Redline 70w90 gearoil its worth the extra $$ per quart IMO
          1987 PRO-3 car /1990 325is (2.7i Concours)
          • AndrewBird
            The Mad Scientist
            • 11897
            Why not just replace the seal AND flush and replace the fluid at the same time?
            • MikesJo
              • Mar 2004
              • 989
              $ to pay a mechanic to do it :). I just flushed it.
              E30 M3 Wallpapers
              • Jparkr
                HR Admin
                • Jan 2006
                • 3494
                no dont pay a mechanic, im a mechanic at a local Tacoma BMW/volvo shop and we charged 95 bucks after tax to do it. you can do it yourself very easily with a 14mm hex head and 2 quarts of whatever oil you choose. it will cost you... 20bucks? maybe and take under a half hour
                • MikesJo
                  • Mar 2004
                  • 989
                  30 mins to replace those flange seals or the oil?
                  E30 M3 Wallpapers
                  • Jparkr
                    HR Admin
                    • Jan 2006
                    • 3494
                    the oil, the seals should be pretty straight forward as well though i would say 2 hours for the seals & oil.
                    • MikesJo
                      • Mar 2004
                      • 989
                      Ok. 30 mins to change the seals sounded off, lol. I got the oil changed for $24 cdn.
                      E30 M3 Wallpapers
                      • Koony
                        • Mar 2005
                        • 261
                        ditto. Might want to add Lube Gard LSD additive (or equivalent) also.
                        • 92 mtechnic cabrio
                          • 4907
                          god that stuff stinks
                          R.I.P 07/01/09 - 04/23/10 :(
                          • Koony
                            • Mar 2005
                            • 261
                            No doubt! They say it's made with whale sperm. I've gotten it on a shirt before and the odor never, ever goes away.
                            • Jparkr
                              HR Admin
                              • Jan 2006
                              • 3494
                              hmm sounds sexy. how much is it. i havent heard of it.
