Active check "rear light" warning
  • Drew325is
    • Oct 2004
    • 520
    Hi all, periodically after I've had the headlights on for awhile the "rear lights" warning comes on the active check panel. However, the tail lights are fine. Does anyone have any ideas on what's going wrong? Cheers!
  • Teaguer
    • Sep 2004
    • 6167
    Bad bulb sockets and/or faulty circuit board in the housings are the likely culprits .
    Turn on the lights and open the trunk and bang on the lights a little and see if that sets of the check panel .
    • NC325iC
      • Mar 2004
      • 6565
      we need to start a little banner that pops up the first time these noobs log on so they stop asking this question
      • AdamF 88iS
        • 2051
        You probably have cheap brass base bulbs. Get the good brand bulbs and it will quit.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Drew325is
          • Oct 2004
          • 520
          Thanks for the tips guys, will look into it.
          What we really need is people to use decent key words in their threads so that when I do a search I find what I'm looking for...then I don't have to post an apparently common question.
          • NC325iC
            • Mar 2004
            • 6565
            i was just givin you a hard time man, that would be good though
            • Drew325is
              • Oct 2004
              • 520
              No problemmo. My older brother is out of town atm, so someone's got to do it!
