Car stalling after starting (PLZ HELP)
  • Tmavého na Světlo
    • May 2018
    • 8
    Hello everyone, I'm a new e30 owner and a new member of the forums. I just got a 1989 325is and it was driving great but then one day I started it and it stalled after a couple seconds. The check engine light is flickering, so I'm assuming it's an electrical or sensor issue. Has anyone had a similar experience?
    EDIT:
    Car sounds like it has a misfire, lots of exhaust smoke.
  • dnguyen1963
    • Nov 2011
    • 2648
    • 06UZ
      • May 2018
      • 26
      Maybe it is AirFlow Meter. You can put out this thing and squeeze WD-40 to socket
      For Sale New Brand E30 parts ;
      http://drive.google.com/drive/folder...x1?usp=sharing
      • Tmavého na Světlo
        • May 2018
        • 8
        Originally posted by dnguyen1963
        I tried it and a few times the CEL turned off after about 15 seconds. Nothing else happened. Am I simply doing it wrong?
        • Tmavého na Světlo
          • May 2018
          • 8
          I'll look into it. Thanks
          • dnguyen1963
            • Nov 2011
            • 2648
            It is a bit tricky the first time doing it. Make sure that you depress the throttle all the way to the floor in a smooth motion. You do not need to press too quickly. Do it 5 times and the CEL light should start blinking. Which position is your key at?
            • othatseric
              • Jul 2016
              • 199
              if you can get it to idle maybe check for vacuum leaks
