Mtech1 Steering wheel on airbag wheel swap?
  • Alpine003
    • 376
    I just tried installing an Mtech1 steering wheel onto my airbag model without success. I guess I assumed it would be a direct bolt on. Do I need a special snap ring off the Mtech 1 or non airbag models for the horn? Any pointers or directions on this? I did a search and not enough turned up.
  • JPL
    • May 2005
    • 774
    i've heard you have to throw some washers on so the wheel doesn't get in the way of turn signal arm while turning. but i've never done it. hopefully someone will chime in who has.
    Originally posted by Hawt drift chick
    Yeah, i'm a good dude i swear, i just like to be balls to the wall.
    • X2theZ3
      • Mar 2004
      • 932
      you just need a small washer/spacer.
      • Alpine003
        • 376
        Thanks, I found out a couple answers.
        For everyone in the same boat, you'll need some washers and also to cut off or push in the srs pin switch that gets in the way.
