Couldn't seem to find what an answer in older posts. I just swapped my sunroof crank from manual to electric. Everything was working well, motor worked and then I need to make some adjustments as the sunroof was not closed fully. Knowing that you can manually adjust where the bolt is, I figured this is what I would do. My dumb ass took a socket to the bolt, INSTEAD, of using an allen key and seemed to have messed things up. The motor still makes a sound like it is working, but it is not moving the tracks well. Question, is there a way to reset the motor or adjust the bolt properly since I messed it up?
Thanks
Thanks
