Help fixing my fuel leak.
  • doucy2
    • Sep 2006
    • 1311
    Drivers side, to the right of the rear jack point (from underneath POV)
    there is a rubber line then the fuel pressure damper then the steel gas line that goes to the engine. the place that is leaking is the metal end on the damper over the rubber line, that metal piece is rusted out and has a gapping hole!!!!
    what parts do i need to fix this, and what will i have to do to fix it. reason i am asking i wanna get all the info together because my friend has a lift i can put the car on and work on it.
    any help is appreciated
    cheers
    _________
  • Graham325
    • Sep 2004
    • 399
    bump, I have this same problem I think
    • lordofthewaters
      • Oct 2005
      • 714
      Just pull the damper and replace with a fresh piece of hose. Mine never had a damper on it (not since I got it anyway). Pretty common solution. I don't think you can even get those at a dealership any more.
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • BoostedGT
        • 11
        I had the same problem with a rusty/leaking damper. I removed it and and added a rubber fuel hose in it's place.
        • Graham325
          • Sep 2004
          • 399
          what do you guys mean by damper?
          • e30 owz yo
            • Mar 2006
            • 6
            More info on the damper please, I think I might has this same problem.
            • doucy2
              • Sep 2006
              • 1311
              Just remove the damper and put on new rubber lines and eliminate the damper altogether
              it worked fine when i did it.
