Elephant trunk
  • dcover7
    • Aug 2018
    • 14
    Elephant trunk
    Is the elephant trunk for draining the cowl compartment (the area below the windshield inside the air vents). I've heard different things, wanted to make sure.
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    Yeah, it's the little black rubber spouty thing nearly behind the valve cover on an M20 car
    Sent from my moto g(6) using Tapatalk
    (OO=[][]=OO) For Life
    • tomstin
      • Mar 2015
      • 570
      Also, check for junk in that area as the cowl also drains out each side behind the fenders.
      2004 525i Manual - 1985 325E Coupe Manual
      • dsphil
        • 495
        That thing is damn expensive.
        327is
        325es
        325es
        318is
        Fiesta ST
        E46 M3
        • dcover7
          • Aug 2018
          • 14
          Yeah I know, $35 is so steep for a rubber piece. Mines hard as a rock and I can’t get it back on after taking it out to clean
          • wolfador
            • Mar 2018
            • 33
            same here, I just left it out after trying to get it back in place.
            86 325e sedan
            • Magnaflow Cat-back
            • SSSquid Stage 1 Chip
            • dcover7
              • Aug 2018
              • 14
              I just ordered a new one, cheapest I could find was 40 incl shipping :rippedoff: I wouldn’t leave it off for long. Without it, water would probably drain behind that firewall insulation where it would never dry. I can’t deal with anymore rust issues haha. Just to be sure, you twist it clockwise to put back on right?
              • 15Michaeljoseph
                • Aug 2013
                • 1693
                Yeah, just jam it on there
                • eeeks
                  • Dec 2004
                  • 71
                  I was able to soften mine a bit when I had my E30...soaked it overnight in some rubber and plastics conditioner
                  Clean the opening where it goes back in fairly well and use a bit of dish soap to finagle it back in
                  1987 325/4 *Grumpy*
                  1996 328isaS/C *Angelina*: the *sirius* ubercommuter
                  • dlmrun2002
                    • Apr 2007
                    • 808
                    rubber
                    Put it in the microwave or soak in hot water then try putting it back in.
                    dlm ny country
