I keep blowing fuse #11 (Labeled-"Injection Electronics").
It does not happen immediately after starting the car. Usually after driving atleast a few miles it will blow the fuse. I have installed a new fuel pump and have changed the fuel pump relay thinking one of those may be bad. The voltage at the fuse (while car is running) only shows 11.8 volts while other circuits are showing around 12.2 volts. Anyone have any other idea at what may be causing it to blow. It can not be a dead short as it does not blow immediately. Does anyone know what other components are running through this circuit?
Thanks,
Dan
1991 318is M42
Thanks,
Dan
1991 318is M42
