No start on m20 1.3 swap. No start
    2.7i eta block with 885 head ecu wiring harrnes and all sensors for E to i swap
    injectors are not firing. I have power to injectors. I have continuity between ecu and injector bank 1 3 5 and bank 2 4 6 at ecu pin 17 - 16. Cps is correct ohms and cps connector has continuity to ecu. I have fuel presure. 45 psi at rail when cranking. i have spark. Will run if i prime but die because i am not geting fuel. Compression is good
    Are there any ideas you may have, any other tests i sould preform?
    Am i looking ecu replacement? Or is there a way to test ecu injector driver?
    Thanks in advance. Tz
