I just finished rebuilding the m20b25 in my 89 e30. My battery needs replacement, I know itÂ’s on itÂ’s last leg and IÂ’ve been trickle charging it to start the car and drive it around the block for the last few days.
The other morning I turned the key and no click, no start. 12.5 v at the battery. Not worried too much, thinking it was not enough juice, I tried to charge it a bit more. During this time it disassembled the tach to tighten the grounds on my flakey gas and temp gauges. Put it all back together, attached the battery, (12.5v) and still no crank.
Noticed the backlit bulbs turn on but no check engine, or row of lit ones at the bottom. No hvac. I have turn signals but no headlights or hibeams. No power windows.
I jumped 11/14 and the starter cranked. Tried this again with the key in the on position, but no start, just crank. So, ignition switch? I tried to test between 1/15 on the coil and the ohms said 1.5? (IÂ’m probably doing that wrong). About to get a new battery because I know itÂ’s time but because it cranked it is probably not the issue, right?
Thanks for any suggestions, happy Halloween.:devil:
