Noob Member With a Noob Question
  • ButtJuice
    • Dec 2009
    • 2609
    I have a question that I’m sure has a simple answer. I’ve searched and spent money with no cure.
    When I put the headlights on, the OBC dims to the point where you can barely read it, the tach/temp gauges do not illuminate, however the speedo and temp gauges illuminate. When the headlights are switched off, the OBC illuminates bright.
    All the bulbs are less than 1.5 years old, I already swapped the headlight switch (nothing changed) and I checked the fuses a dozen times.
    I’m pretty stumped! Would appreciate some fresh ideas.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
  • ButtJuice
    • Dec 2009
    • 2609
    Also the Si board is solid, replaced it with a refurbished one from BavRest, swapped the defrost & emergency light switches as well.
    What thaaa fuhck
    1991 318is - Sold
    1986 325 - Sold
    • Nader393
      • Dec 2015
      • 408
      Sorry, I don't have an answer for you. But I acknowledge how humiliating it must be for you to ask for help, while calling yourself "Buttjuice."
      '91 325i
      • Nader393
        • Dec 2015
        • 408
        Well, "Buttjuice", I gave it some thought. Check your grounds. Especially the grounding stud on the inside of the front left fender.
        '91 325i
        • ak-
          • 12422
          Your alternator needs Viagra
          1991 325iS turbo
          • IRON-E
            • 16548
            And his ass needs less red bull.
            @IRON-E30 aka Edwin:D
            • kronus
              • Apr 2008
              • 13023
              Have you played with the cluster light dimmer?
              cars beep boop
              • ButtJuice
                • Dec 2009
                • 2609
                I can’t express how thankful I am.
                I rubbed Viagra on my grounds while reducing the Red Bull intake, lo’ and behold this son of a gun illuminates like it came fresh off the lot.
                1991 318is - Sold
                1986 325 - Sold
                • ELVA164
                  • 4861
                  What a nub lol
                  Electrical issues are a nightmare. When I was at Sebring this month, Dad called and said the left-side turn signals had started flashing quickly but both ends and the dash all worked. I ordered a good used switch on the way home because my research suggested that would be the source of the issue (Dad checked relays, fuses, etc. with no success).
                  I got home, the second flasher relay and second switch made no difference. I took out the front-left bulb, put it back in, and everything is fine now.
