i am going to pull a diff. from a "u pull it" lot. Does anyone know what size hex. bolts are on the CV shaft connecting to the diff. flange?. Also what other tools would i need? thanks Matt
diff.
8mm hex for the axles.
17mm box wrench for the driveshaft bolts and the bolt on the top of the diff.
2 19mm wrenches for the hagner bolt.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Almost right.
The bolts on top of the diff are 19mm headed bolts, there are 4 of them. I find that a 19mm stubby ratchet wrench is worth it's weight in gold for loosening these once you break them loose with a 19mm box end wrench.
BretComment
The diff is easy to remove too so you should not have any problems:pOriginally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
Youre right. I had a brain fart on that.Adam Fogg- '88 M3
