Trans pan
  • Freakshow
    • Apr 2013
    • 174
    Trans pan
    Hey R3V I’m having trouble figuring out where this leak is coming from under my transmission pan. I have replaced the trans pan gasket and the selector shift seal. Just when I thought that fixed it there was another puddle under my car. I’m not sure where the leak could be coming from.
  • roguetoaster
    Biggus Tippus
    • 7814
    Input/output seals, cooler line fittings?
    • AndrewBird
      The Mad Scientist
      • 11898
      Are you sure it is ATF? If it's motor oil, could be a bad rear main seal.
