Axle Nut Hell!
  • GoochE30
    • Jul 2018
    • 55
    Axle Nut Hell!
    Hey guys,
    I’m trying to do a front wheel bearing on my 87 325. The axle nut is horrible 3 ft breaker bar with 3 ft pipe won’t loosen it up. So I’ve wanted an air compressor upgrade so I grabbed a harbor freight 21 gallon and their earthquake impact (rated at 950ftlbs). The nut wont budge! Is there an issue with the impact gun or are these nuts really this difficult?!
    Anyways any ideas are much appreciated! If I can’t figure it out, I might end up cutting the nut off. I just figured the gun would strip it long before it gave up.
    Thanks
    Tommy
  • roguetoaster
    Biggus Tippus
    • 7830
    Did you mangle the bent over tang out of the keyway in the axle?
    Spec on the fronts is pretty high IIRC, maybe 200ft/lb, so it'll be on there nicely.
    Personally, since I've had a decent electric impact I haven't encountered any fasteners that I cannot remove. So, if you are at that stage I suggest soaking it in penetrant over night, trying 10 or so small blips of the gun the next day, and failing that I'd move to heat before resorting to cutting.
    Also, depending on the line/line pressure settings you are using you might not get full power on your impact. Also, oil your air tools if you haven't already.
    • GoochE30
      • Jul 2018
      • 55
      Thanks for the response. Yea I’ve bent the tab and oiled the tools. I might need to consider a line upgrade but the regulator is at max psi.
      • ButtJuice
        • Dec 2009
        • 2609
        Lefty loosey righty tighty?
        1991 318is - Sold
        1986 325 - Sold
        Instagram - Lamoursum
        • dnguyen1963
          • Nov 2011
          • 2649
          Can't make this mistake with an air gun even if it is HF quality.
          • nrubenstein
            • 3148
            I would suggest trying to borrow the big Dewalt or Milwaukee battery impacts.
            Air tools suck. Cheap air tools suck even more.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • TimeMachinE30
              • Jun 2014
              • 3749
              I'd love to try my high torque M18 Fuel 1/2" pin detent on it......
              ACS S3 Build / Dinan 5 E34
              • nrubenstein
                • 3148
                Don’t forget that HF ratings for tools are frequently optimistic. By some multiple.
                (And to be clear, I have nothing against HF. I’ve actually got a couple of the 72” toolboxes in my garage.)
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5556
                  950 ft lb impact is not powerful enough.
                  I struggle to take them off with a 1400 ft lb one.
                  You need to torch it
                  • LateFan
                    • May 2013
                    • 4404
                    The SMOKE WRENCH!!
                    • GoochE30
                      • Jul 2018
                      • 55
                      I'll give it a go with the torch and report back back
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5556
                        It will work with a torch, but not with one of those little propane ones, (sorry hank Hill)
                        You're going to want to use an oxy-fuel torch
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          IIRC those MAPP/MAPD and O2 kits you can get at home improvement places produce nearly the same temps as an acetylene/O2 setup. But MAPP alone does something like 35% less temp output without O2.
                          • GoochE30
                            • Jul 2018
                            • 55
                            Finally got the SOB but hammered so hard it messed up my tie rod end. Hopefully that will be an easier job. Thanks
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              Good to hear, but what in the world were you doing to roach a ball joint, or did you just split the boot?
