1987 325e No Power to Injectors and And Fuel Pump
  • Thrinmon
    • Feb 2019
    • 2
    Greetings BMW enthusiasts,
    I recently came into ownership of a 1987 325e. I picked it up stupid cheap because the previous owner had too many projects and didn't feel like getting into this one. I have insofar been unable to make the stupid thing run, even though it apparently ran when parked (albeit in 2003) The car has spark and will occasionally sputter to life for a second or two if given a shot of starter fluid into the intake. I've tried replacing many parts (Fuel pump, relays, CPS, ECU) to no avail. The problem seems to be electrical which is absolutely not my strong suite and I have little experience with BMWs in general, so any help or advice would be much appreciated.
  • dnguyen1963
    • Nov 2011
    • 2649
    E30s are notoriously sensitive to bad grounds. I would check and replace any bad ones first. If the car has been parked, there is a strong probability that mice might have made homes in the car and chewed up the wires.
    • Thrinmon
      • Feb 2019
      • 2
      Mice have definitely made themselves at home in this car at one point or another, though most of the wires I've seen have been in good shape (luckily). Though now that I think of it something did smell a bit funny when it turns over. I'll check back in after I look them all over.
      • RobDog
        • Aug 2012
        • 188
        Check your OBC relay and jump the green and green/red wires if the relay is bad or not passing voltage through those 2 wires mentioned. Those wires provide power to the fuel injectors
        • e30austin
          • 15382
          Fuseable link. Make sure the smaller wire, that goes with the large battery cable, at the power distribution block (at the firewall) has 12v going to it.
          Otherwise, check all your grounds, confirm that your DME is a known good, working unit, look at jumpering the OBC relay box (to bypass the fuel pump lock out) and lastly...make certain you have good battery connections and a good battery!!!
          • jbontke
            • Mar 2019
            • 449
            If you get 12v at the fuel injectors red/white wire, then the main relay (OBC) are fine. This is straight form the Bentley manual, I am in a similar situation.
            There is a cold start valve (fuel injector) on the end of the intake that has a fuel line running to it. That should spray for 8 seconds and at least let your car run for a second or two. Sounds like you may not be getting fuel. If you jumper the #87 and #30 (look on relay for the exact position) prongs on the fuel pump relay, do the fuel pumps run?
            • Fryedchicken34
              • Apr 2026
              • 11
              Were you able to figure out what the issue was. I’ve been trying to find out for the past couple of weeks with no luck
              • jbontke
                • Mar 2019
                • 449
                Well, this was... 7 years ago?? I drove the car for 50k miles since then. So I must have figured it out. What is your issue?
                • boyerefren
                  • May 2026
                  • 1
                  drift boss
                  Good reference to the Bentley manual, that usually points you in the right direction. The suggestion to jumper the relay pins is especially useful for quickly ruling out pump issues. It definitely sounds like a fuel delivery problem based on what you described. Were you able to hear or feel the fuel pumps running when you tried the jumper test?
