So I put a clutch in my iX a little while ago (two months maybe) and everything has been fine until now. A few days ago I gave the car a little workout if you know what I mean. Now whenever I drive the car in an somewhat agressive way I get a little squeal or honk noise from what sounds like the clutch area whenever I shift up to 2nd or 3rd. It doesnt do it when I downshift though. It just happens really quick and almost sounds like a tire chirp when hitting second gear. I guess it kinda sounds like a saxaphone or a horn or something. Thats the best way I can explain it. Anyway if anyone has any ideas what this sound could be let me know.
Clutch noise?
Tags: None
Sounds like my sister's 97 civic's clutch. She needs a new clutch in maybe 10-15K miles. You just put a new one in though. Does it make the noise while driving normally? (Granny shifting)Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
mine makes a chirping noise into second, but that isonly because i barely let off the accelerator as i shift. my clutch hates my guts......Comment
Well drove the car today and it doesn't seem to do it anymore. Maybe driving hard just made a hard hot spot on the disc ore something that caused it to make a harmonic noise. I dunno but I will keep you posted. No it does not make noise when I drive like my grama.
1989 325iX
1995 540i
1986 325eS R.I.P.
1984 325e R.I.P.Comment
I dunno but I thought it wasn't doing it but I guess it still is. I used a lot of white lithium grease on the TO bearing shaft and the clutch disk is brand new. Is it possible that I may have put the pilot bearing in too deep? It seems like it went in pretty far.
1989 325iX
1995 540i
1986 325eS R.I.P.
