Help identify this
  • marsgorski
    • Oct 2018
    • 28
    Help identify this
    Found it in a box where I put other things belonging to my 87 325e. But i don’t remember ever pulling it out of the car
  • Sonny
    • Feb 2019
    • 100
    Looks like a ground.
    Maybe that would be connected to valve cover bolt. Check YouTube "replace valve cover gasket *YOUR CAR*"
    AND see if one of the first steps of unbolting it involves a ground cable like this. I can be wrong as my car is different .
    Check alternator connections.
    Check starter connections.
    Does the car have issues running? Does it start at all? need more info please.
    Sent from my Pixel 3 XL using Tapatalk
    • marsgorski
      • Oct 2018
      • 28
      Thanks! I will check it out tomorrow.
      It does have issues! But the issues are relatively new (a few months) The connection I found must have been pulled out >4 years ago.
      The car starts, but it will immediately shut off (most of the time, specially when it’s cold outside) if I don’t press on the gas. Sometimes it will also shut off while driving. This is a problem I’m trying to figure out at the moment.
      I also found this:
      Seems to have a button where my thumb is. I thought the number by the BMW logo was a part number (19139682) but I didn’t find any parts with that number on realoem.
      • IRON-E
        • 16548
        Maybe part of a lock mechanism?
        @IRON-E30 aka Edwin:D
        • Sonny
          • Feb 2019
          • 100
          I also found this:
          Alternator maybe? That or a lock switch,I've yet to check my Bentley manual I'll post photos of the pages later on when I can boss
          • Todd Black 88
            • Oct 2007
            • 3449
            I also found this:
            Central locking door lock microswitch
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • Caperix
              • Feb 2018
              • 194
              Passenger side door lock switch. The 2 is a revision number, if you drop that you get results.
              • marsgorski
                • Oct 2018
                • 28
                Thanks! you're correct about this.
                Still haven't been able to figure out the wires in the first picture. I saw some videos of people removing the valve cover and I don't see anything like it on there.
                I noticed there's a tiny number on the black plastic area, looks like 61311375199 but the numbers are so tiny I may have gotten some of the digits wrong. Nothing turns up on realoem, but I do find something with the number 61311375198. The weird thing is that this part is for an E28, not an E30. It does have some resemblance to the part I have. Does anyone know what a "Contact interior light retarder" does?
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  That looks a lot like the door lock heater mount, or the same component on E30s as on the E28 P/N you gave. E30s would be 61311375197 and 61311375200, and I assume it's a delay or auto off system for the interior light. Although no E30 I've had has that feature as best I can recall.
