So did a steering wheel swap this morning on my ‘91 ix. Went from factory w/airbag to Nardi D with Nardi hub. Also deleted the srs box at same time. Horn worked with original wheel right before but now nothing. There is some forward and back motion with the wheel so I’m guess I still need a spacer, thought with the Nardi hub I wouldn’t, and if I push all the way in hard there seems to be some spring tension as well, my guess is I didn’t quite snap the white rod off flush. Anything ideas on easy things i over looked(I did plug in the horn wire to new wheel)
*Edit ignore this*. Also after doing all this and reconnecting the battery the “check” light is on and flashing, coincidence? Or result of srs delete maybe? *I was a dumb*** and didn’t hit the brake pedal to turn that off after start up , leaving Incase it helps someone*
