Left Turn Signal Turns On When Pressing Brakes
  • e dubb
    • 16
    I am having a weird issue with my 318is. Whenever I press the brake the left turn signal on my cluster comes on. Has anyone else ever experienced this?
  • Sonny
    • Feb 2019
    • 100
    Same issue. Remove bulbs from tailights, wire brush connections, reinstall .
    • e dubb
      • 16
      Thanks! I will give it a shot!
      • cheffy30
        • Sep 2016
        • 1159
        you're trusting sonny?
        wtf. good luck.
        sent from hell using Tapatalk
        '90 325i sedan daily driven
        '85 325e coupe also a daily
        • AndrewBird
          The Mad Scientist
          • 11898
          Your left brake/turn signal has a bad ground causing the brake light to ground through the turn signal bulb filament instead of the ground. Clean everything up as Sonny suggested and check the wiring for shorts and/or corrosion as well.
          • e dubb
            • 16
            I cleaned them up as Sonny suggested and all is back to normal. Thanks everyone!
