I was able to pull off my whole shifter?
  • deca
    • Mar 2019
    • 31
    I was driving my car today and noticed that the shift feel felt off.. I went to investigate and when I was pulling off my shift knob I was able to pull the metal shifter off to? Does anyone know why this happened? I wasn’t even pulling particularly hard. Attached are some pictures, because I don’t know the technical term for what I pulled off and don’t want to confuse anyone:
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users like ElliotDa.
  • Sonny
    • Feb 2019
    • 100
    Rethread with loctite? But if this was me I would disable the car and yank out the transmission for some new parts and your definitely going to need a solid set of shifter bushings.
    Put the boot back on to, it’s there to keep dirt from the shifting mechanism.
    Maybe that’s the cause of failure?
    • deca
      • Mar 2019
      • 31
      The boot went straight on after taking the picture. Was planning on putting a Z3 shifter in the car regardless haha, guess this gives me a reason. Thanks for the help!!
      • E30SPDFRK
        • 5716
        Read Sonny's user title before listening to him.
        It looks like you have the early style shifter plate made of steel. If that is true, you can't use a Z3 lever without converting to the later style aluminum shifter.
        The factory levers are isolated with rubber between the 2 metal halves, the rubber is vulcanized to the 2 parts and should never come apart. Your lever has broken. You can try to re-glue it together with epoxy or similar, but the correct fix is to replace it.
        Byron
        Leichtbau
        • LJ851
          • 7919
          You have a early style shift lever that is not vulcanized together but is able to be disassembled and reassembled. The assembly is held together with a wire snap ring at the bottom.
          I have used multiple late model shifters in early sheetmetal carriers without a problem.
          Lorin
          The M30 is God's engine.
          • deca
            • Mar 2019
            • 31
            Just noticed that aha.. so the correct fix would be to replace the lever? Or the shifter as a whole?
            • glnr13
              • 1334
              I'm confused by this. I have an early shift plate with a z3 lever intake in my car, on it's second iteration. initially I had just the lever installed with the shifter plate and now with the same lever I've modified my shifter plate and switched to a dssr. In both cases the z3 lever fit fine however user has to snip a collar to get it to go over the lever ball joint
              • glnr13
                • 1334
                I can tell by your answer that you've never done an E30 shifter disassemble. Your intention is good, you want to help, but your misinformation destroys the integrity of your intention.
                • Sonny
                  • Feb 2019
                  • 100
                  I’m sorry , but just trying to help since everyone helped me
                  • E30SPDFRK
                    • 5716
                    Did I just become Sonny myself? I remember trying to fit a late model shift lever into my early carrier and the pivot balls were different sizes? It was a few years ago, maybe I'm remembering wrong.
                    Byron
                    Leichtbau
                    • glnr13
                      • 1334
                      You might be remembering that you can't get the collar and spring thing on without cutting it?
