headlight problem
  • brandondan1
    • 1091
    headlight problem
    This probably is a dumb question, but today after changing out some vacuum hoses I wanted to see how the car would run. So, I started the car up turned the headlights on and then without thinking cut the ignition off without turning the lights off to go get something out of the house. When I turned the car back on i noticed my left headlight had died.
    I turned on the highbeams and all four lights lit up, but when i turned the high beams off, my left low beam would not stay on. I tried swapping in new fuses (#13 for left low beam, right?) but nothing works.
    So... does anyone know what I can do to fix this? I don't want to get stopped by any cops ><.
    91 318is
  • Van Westervelt
    • 9365
    if you have sealed beams try swapping them to see if its a bad one.
    • MikeE30325i
      • 2356
      well the problem sounds out of the ordinary, but did you check all the connections in the back of the headlight? there shouldnt be a problem with shutting off the car with the headlights on, i do it sometimes and nothing like your problem ever occurs. it is probably something that relates to you working on the hoses, but check all the connections
      • E30 Reaktionär
        Site Manager
        • 14451
        I'm guessing that they are sealed beams since all 4 light up with the highs. You'll have to buy a new low beam since it is burned out thay ain't very much..
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • Van Westervelt
          • 9365
          Ellipsoids light up all 4 if your car was wired for them.
          • E30 Reaktionär
            Site Manager
            • 14451
            ahhh did not know that, learn something everyday...
            1992 BMW 325iC
            • brandondan1
              • 1091
              Thanks for the fast responses guys. I'm thinking i might've loosened something when trying to take out that damned vacuum hose that runs from the top of the valve cover to the throttle....or not
              Are there two elements inside the low beam, and thats why they light up when I use the high beams? They're non-ellipsoid lights btw.
              91 318is
