I have an occasionally bouncy temp gauge. Often mentioned is a brass nut / ground to check. Any intel on how to spot this item and what needs remove to do so?
Where is the brass nut at dash / jumpy temp gauge
It's on the back of the cluster itself. You can see it next to the wire harness plug. The blue plug is next to it. The other nut next to the white plug is the same--for the fuel level gauge.
I believe it's 8mm, but I could be wrong(6mm?). I recall that you can reach it with your hand if the knee panel is removed from the dash, as most e30s don't have them anymore... Otherwise, you can remove the cluster and access it. Don't break your cluster ears :)
here's a photo I found of the cluster back:
Turbo: 221whp/214ftlbs, MS3x flex @ 17psi -
Correct'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
