Bumpiness Under Heavy Acceleration
  • Tmavého na Světlo
    • May 2018
    • 8
    Hello all,
    I have noticed a crisp bumpiness that appears when I am accelerating quickly, most noticeably in first gear, but sometimes in second as well. It feels as if it is coming from the rear of the car. I have also noticed some bumps as higher speeds under even slight acceleration. Could this be a CV joint issue or a differential issue?
    Thank you
  • absolutdog
    • Apr 2012
    • 449
    Bad drive shaft?
    When the center support bearing dies, the shaft hits the trans tunnel during accel, but balances out at speed.
    But it could be a lot of things, put a hand on everything to see what has play.
    87 'vert~~~~~~~89 s50~~~~~~~~~91 318i~~~~~~~~87 s50~~~~~~~~~R.I.P. '91 318i
    I Need used SIR tools
    • ELVA164
      • 4861
      Could be CSB, could be driveshaft u-joints, could be halfshaft CV joints, etc.
      • HerbE30
        • Nov 2015
        • 538
        In my experience it was a tire with a broken belt. Tires themselves looked fine.
        Could be CSB though.
        20% Accurate
        Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
