Semi Broken Temp Gauge?
  • onesecond
    • Apr 2018
    • 159
    I was having temp gauge issues with it overheating but it being inconsistent and also random quick drops in temperature to slightly below the 1/2 mark. I followed this video to rule out rust and loose nut on the cluster https://www.youtube.com/watch?v=01N5G6fZTVI
    With everything back together it now will never go past the 1/2 mark but both radiator hoses are pipping hot, I mean the bottom one was almost as hot as the top one.
    That's the highest it went but the needle would always drop once I started driving and cool air would flow through.
    tl;dr I think I screwed up my temp gauge trying to fix it
  • AndrewBird
    The Mad Scientist
    • 11898
    Use a laser temp gauge to check the actual temperature. Everything is probably working fine now and you don't have an issue.
    • onesecond
      • Apr 2018
      • 159
      Looks like you were right, that's a relief (rather it cold than too hot)
