Hi R3v,
I posted about this issue a while ago, ended up trying a few things to no avail, so I figured I'd ask again and see where to go from here
I was driving my car on the freeway one night, keeping constant speed, and all of a sudden, it sputtered once then just died. Once i pulled over, the car wouldnt start anymore. It would crank but never turn over.
I did a stomp test and got a 1211 code. I did try to disconnect the DME for a bit to see if a reset would help but had no luck.
All instrument/console electricals seem to be working fine. Gauges and all buttons light up. However, I could hear a buzzing noise from within the DME. So I tried replacing the DME thinking it might have gotten shorted somehow, but the same issue persists with the new one. (The buzzing noise happens with both units)
I do have a WAR chip installed in the car, not sure if that might be the culprit? I'm a bit hesitant to get a replacement for that and find out it's not the source.
Are there any tests I could try or maybe additional suggestions as to what it could be
