Very weird fuel pump relay issue M42
  • M42Power
    • Dec 2009
    • 519
    Hey guys, I'm having a very peculiar problem with my car and I'm stomped. I searched around and can't find a similar problem. Here is the context:
    -Fuel pump relay does not click
    -DME relay clicks and sends 12v to exciter pins of the relay
    -Relay has 12v between pin 30 and 87
    -Relay exciter is earthed
    -Car runs if I jump pin 30 and 87
    -Tested relay on another battery, it clicks
    -Tested with different relay, same result
    -Pump won't run if pins aren't bridged
    I can't figure out why it does not activate the relay, starting to believe it is witchcraft
    Originally posted by kendogg
    Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
    OG RACECAR
  • jrobie79
    • Mar 2006
    • 2526
    crank position sensor
    1991 318i ---- 308K - retired
