Anyone recognize this plug? E30 M20b25
  • bangn
    • Sep 2011
    • 760
    Currently modifying a spare M20b25 E30 harness I have to be plug and play with a haltech.
    I came across this plug which ends up plugging into the white C131 inside the cabin. Internally has 2x wires. Also has a bit of
    a heat sleeve on it. Has a metal fitting on the end.
    Internally -
    1x Violet - traces back and changes colour after C131 and heads off to C101 and shares a Fuel pump relay pin.
    1x Brown - goes to pin 33 on the DME
    No wiring diagram shows #33 off the DME nor any info against C131 other than on the neutral park switch diagram outlaying the one wire for NPS
    no info shared about the other violet and brown wire sharing the same connector
    Im thinking it might screw into an Auto trans?? Any help appreciated as Ive spent 2 hours going through diagrams and its doing my head in.
    Link of connector below
    Image IMG-20190803-163612-resized-20190803-044234301 hosted on ImgBB
    Free image hosting and sharing service, upload pictures, photo host. Offers integration solutions for uploading images to forums.
    Boris - 89 E30 325i
    84- E30 323i
