I have been asking around but have had no such luck. Maybe some of the e36 guys have an idea.
I replaced a door that was dented recently and have been having an intermittent starting issue.
Previous to door swap:
My car would only start if the drivers door was open. If it was closed, it would start intermittently. Sometimes it would crank like half a turn and then stop. Closed it would take me 15 tries, open it would take me 1. If the door was open, it would start religiously.
Post door swap:
My car has the intermittent starting problem whether the door is open or closed. Starts once out of 15, door open or closed. Maybe a short in the wiring harness?
*Notes*
1)I used a door from a 92 on my 93 325is.
2)I used the wiring harness from my 93.
3)I don't like driving E36's as much as E30's.
Anybody have any ideas at all? What parts in the door are even related to starting? Is the car not supposed to start unless the doors are closed if working properly? I think I might try swapping the wiring harness from the 92 door in this weekend and see if it helps.
Any tidbit of info would help tremendously.
Post door swap:
*Notes*
