How do emblems attach?
  • Mastrcruse
    • Sep 2005
    • 5340
    I have searched but haven't really found what I want to know. I am wondering how are the rear "325i" emblems attached to the car? Are they attached with some kind of adhesive?
    If I would to take mine off would there be holes?
    Thanks
    DJ
  • AdamF 88iS
    • 2051
    They are glued. No holes.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Van Westervelt
      • 9365
      its pretty much 15-20 year old strong double sided tape matched to the badge size. heat gun on low and then some adhesive remover. just dont bubble your paint.
      • Mastrcruse
        • Sep 2005
        • 5340
        How bad will the glue be to get off? Will the paint be nasty/discolored under them?
        • kencopperwheat
          King of Kegstands
          • 14396
          not if you get it all off... which is a pain. I used a hair dryer and some dental floss and I got almost all of it off.
          Originally posted by Gruelius
          • doucy2
            • Sep 2006
            • 1311
            yea my friend did that on her celica with a hair dryer and floss, only time you can tell it was debadged is when the car gets really dirty.
            • AndrewBird
              The Mad Scientist
              • 11897
              For future reference, the roundels are held on with pins.
              To remove them, place a credit card or similar card next to the roundel. Then, CAREFULLY use a small straight-blade screwdriver to remove it, prying agaist the card.
              • porsche gt1
                • 237
                2 times to that
                • Mastrcruse
                  • Sep 2005
                  • 5340
                  The guy assured me that he can get them off before shipping so I guess all I can do it trust him and ask him for a pic before he sends it to me.
                  Thanks for the help.
                  • Van Westervelt
                    • 9365
                    he stated pretty clearly it was about the "325i" emblem. not the roundels. so the roundel removal tips although accurate, don't work for his question.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      if you use a little TB cleaner it comes off easy, just make sure you clean it all off quick, then hit it with some buffing compounds
                      • AndrewBird
                        The Mad Scientist
                        • 11897
                        Hence why I said "for future reference". That way if someone searchs on the subject, they will find their answer. His original question was answered after the second post.
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          What about the 3rd brake light on a vert? Glue or bolts/pins?
                          • AndrewBird
                            The Mad Scientist
                            • 11897
                            I believe those are bolted. Someone correct me if I am wrong.
                            • Jand3rson
                              • 37587
                              I didn't even use a hair dryer, I just used a piece of sewing machine thread and stripped the emblem off, then used Goof-Off for the adhesive. After I got it all off, I used cutting compound to get rid of the outline, and then waxed the area. I need to cut it again though, at certain angles, you can still see the ghost outline of the adhesive.
