You can download the video that has the sounds in it here:
http://www.r3vlimited.com/Media/Videos/Firstdrive.avi (15MB)
or just the audio ripped from the video here:
http://www.r3vlimited.com/Media/Sounds/Noise.mp3 (1.4MB)
I spent the entire damned day trying to figure out where this noise is coming from.
Currently the following items are off the car, or are not driven so cannot be making the noise:
Alternator
Power steering pump
Water pump
Engine driven fan
(A/C is already deleted)
I took the front crank pullys and gear off, and the timing covers. I cannot find anything that is rubbing on the timing belt, so everything looks good there. With the engine running I was unable to pinpoint where the noise is coming from, it seems like it is everywhere.
It is engine speed dependant, as the sound clip should show. However it must be forward of the flywheel as I can have the clutch in and the noise remains unchanged.
The sound is most "potent" as the engine is starting, and getting up to speed. After this it is somewhat masked by the engine itself but is still perfectly annoying.
Alternator
Power steering pump
Water pump
Engine driven fan
