AFM cleaning question...
  • a3ternus
    • 643
    I know many of you will think its a stupid queston but I have to ask!
    Can I clean my AFM which lately gives me troubles (Idle not steady,
    at one time the engine felt clogged and didnt exceed 3000rm,only once though)
    using some kind of what is generally known as "Carb cleaner" or any anti rust,anti moisture spray (spraying directly in the intake while the engine s running) or this would be a bad thing? How can I clean it a bit? :roll:
    N.
    PS.Now,THATS a big sentense dor you all! :p
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
  • e30 gangsta
    • 3877
    I belive they sell mas air flow cleaner that you spray into your intake. I Dont know if you could use that though.
    • 87-325ic
      • Apr 2006
      • 1198
      just that the thing off and wipe it out with paper towels, carb cleaner/ windex would work if you needed it..
      i doubt your afm is that clogged though, its more likely you intake manifold or ICV (if idle related) or throttle body..
      • e30 gangsta
        • 3877
        Anyone can do that. I think he means how do he clean the afm filament.
        • a3ternus
          • 643
          Thats right...I also cleaned this (See the photo) with the cleaning spray and now it doesnt really seem to respond to my adjustments...Hm...:roll:
          N.
