m50 frozen solid
  • LooN
    • Jul 2006
    • 37
    m50 frozen solid
    My M50TU is seized. Quick rundown of the situation:
    -1992 325i E36. Bought the car about 3 months ago. Previous-previous owner swapped in a remanufactured M50, originally from a 1995 525i. Rebuild was 25k miles ago.
    -When I got the car, it would crank strong, exhaust would sputter, but wouldn't fire. Wiring harness was all cut to shit, so after searching junkyards for a very long time, I found a replacement and put it in. That was about 1 month ago.
    -Ever since I replaced the engine harness, motor would not crank. I thought it was a wiring issue for the longest time (because that was all I'd changed) but just recently figured out that the motor is stuck.
    -Took off the valve cover and found a sorry sight. Camshafts have light rust on them and scoring in a couple spots (luckily not on the lobes though). Light rust is apparent in many places. Very dry--little or no oil on the camshaft and timing chain assembly, probably from so much cranking in attempts to start the car (oil level has been full).
    -I believe this detail is important: When I first got the car, the ignition would crank the motor easily, and the motor sounded healthy. However, by the time I finally obtained a wiring harness, I had been cranking it many times over the period of a month or so, and it had begun to make a very loud squeaking sound when I turned the engine over. It sounded like metal rubbing without lubrication.
    What's the best way to go about trying to unfreeze this engine? It has not been run in about 3 years, but the fact that it cranked easily very recently leads me to believe that I don't need to get it rebuilt. From what I can tell, it sounds like something isn't lubed or has rusted just enough to make it stick.
    Help!! Thanks in advance :)
    -LooN
  • KangamangusDriver
    • Aug 2005
    • 1870
    Hmmm
    Try some mystery oil in the cylinders or penetrating oil.
    Let it soak for a couple days.
    That may help, hopefully there is no rust build up on the cylinders/rings
    If that is the case you may have to rebuild.
    • e30_kid89
      • Apr 2006
      • 489
      o shit! would my motor have a chance of seizing if its been sitting on a engine stand covered down over winter??? should i just throw in some oil for lube? fogging oil??
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        Diesel or Kerosene works as well. I know my best friend's grandfather would squirt Kerosene in the spark plug holes and let it set overnight in older cars that had sat for a long time before attempting to start them.
        Worked every time.
        • bimmerboy570
          • Mar 2007
          • 63
          theres this penn. oil that is amazing for unseizing things dont hit it with a sludge just take your time kroyl i believe its called i have used this before it is amazing stuff
          • BDSax
            Junkyard King
            • Mar 2006
            • 3593
            tranny fluid is your motors friend. a teaspoon in each cylinder will do the trick
            NEED SOME VINYL STICKERS???
            • DJB
              • Oct 2005
              • 195
              What kind of transmission fluid? Manual transmission fluid is pretty much just motor oil with smelly additives.
              • SchnellerVert
                • Sep 2005
                • 3948
                Or marvel mystery oil which is transmission fluid.
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3593
                  auto trans fluid
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Sounds to me like your oil pump is dead. Cranking the motor over should have pumped oil throughout the engine. A lot of guys do this first to "prime" a rebuilt motor so the engine doesn't run the first few minutes without oil.
                    And if the motor is seized, you're going to have to rebuild. If something cause the motor to stop turning over, then there is something seriously wrong. Either a spun bearing or broken rings.
