Really bad idle, heavy fuel smell
  • BimmerKris
    • Aug 2004
    • 116
    cool thanks, there is no leaks underneith the car, and the exsess fuel smell is coming from the exhaust. im gonna try replacing the CSV cause i've been told by a couple people now that it could be stuck open, i'll check into the other stuff mentioned as well
    thanks guys
    • Mike325
      • Mar 2006
      • 3685
      Sounds like you have a spark problem.
      Originally posted by Kershaw
      • Bimmerboy91
        • Feb 2007
        • 622
        this sounds like the same thing im going though.
        so if i have leaky injectors, i would have to replace the o-rings on the injectors? how many are there?
        and is there a way to test the cold start valve?
        • SamE30e
          • Sep 2007
          • 4319
          There is 6 injector o-rings in total I believe. Do you mean the ICV or the cold start injector? If you have an e, its the blue plug on the passenger side of the intake manifold. I have no clue on the I.
          1985 325e 2.8 Turbo VEMS
          • Bimmerboy91
            • Feb 2007
            • 622
            sorry i ment the cold start injector. how you check it?
            • skatebline
              • Sep 2006
              • 167
              Wow.....That is the same exact problem im having at the exact moment.
              Over the weekend i changed my head gasket and now i have it all put back together.
              The timing is right on!
              Ive done eveything i could think of.....
              The car starts just fine and runs kinda rough but while its running the smell of fuel is real strong!
              When i try to rev it up it barly wants to cause its getting waaaay to much fuel. After revin it up a little there a small amount of fuel on the ground back from the exhaust :(
              Dont know what to do......
              • redhatpat
                • Aug 2005
                • 656
                Also check fuel pressure. Too much can overwhelm the injector's seal and the engine will run rich.
                • skatebline
                  • Sep 2006
                  • 167
                  That rich tho!?
                  That gas spits out the muffler? hahaha
                  • skatebline
                    • Sep 2006
                    • 167
                    Problem fixed!
                    The fuel injector wiring need to be rewired and all dont now. runs like a dream :)
                    • bcrdukes
                      • 107
                      Bump to an old thread but for the OP, what exactly did you rewire? How did you figure that out? Can you provide more details?
                      1989 E30 BMW 325i
                      1998 E36 BMW M3
                      2004 E46 BMW 325i
                      • Lyrred
                        • 391
                        bump
                        • b*saint
                          • 3794
                          Fuel line has an air leak in it. Does it clear out?
                          Ma che cazzo state dicendo? :|
