Intake manifold difference?
    • 37829
    Is there a difference in the intake manifold for the i motor and the e motor?
    :?: :idea:
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • Jordan
    • 12913
    yes, the eta manifold runners are alot smaller in diameter, and are overal longer.
    https://mtechniqueabs.com/
      • 37829
      That's what I thought...
      So, would a i manifold bolt on to an e?
      Grover Beach, CA
      www.BimmerHeads.com
      • AdamF 88iS
        • 2051
        Yea it'll bolt on. You may have to make some changes to the plumbing for the idle valve and whatnot, but the main part is a direct fit.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • James Crivellone
          Head Janitor
          • 6304
          Here is a picture of my ETA with an M20B25 Throttle Body + Intake Manifold
          Main issue is the ICV, as well as the FPR Vacuum Hose.
          just takes some routing, I did have to disconnect my intake moisture thingy (little brown tank that goes to the gastank) but that does not really do anything..
            • 37829
            James, that looks good, I see you put the "i" valve cover on too. How much of a gain can you actually feel with the "i" throttle bodyt and intake manifold? I want to do that to my car.
            Grover Beach, CA
            www.BimmerHeads.com
            • bwanac
              • 3354
              I thought the i manifold did not fit on the eta head?
              And what little brown thingy are you speaking of, charcoal canister?
              Looks good, and yes any improvements?
              • James Crivellone
                Head Janitor
                • 6304
                yes, charcoal canister, I was looking for that word, just could not remember it.. =)
                improvements, yeah, it idles better for some reason, pulls harder at around 2500rpm, all the way to redline at 5200
                have not dyno'd it, cause A) its an automatic and B) I would rather buy more parts =)
                  • 37829
                  So, being the die hard ETA fan that I am, :) Do you think I should do this swap?
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • bwanac
                    • 3354
                    And I still want to know how the 'i' valve cover fits on the eta head.
                    I thought that could not work! :?
                    • Jordan
                      • 12913
                      it is a direct swap, what is the issue? there is just a big gay looking eta bracket that gets left off.
                        • 37829
                        Guess I need one of those too......... Yay :) lol
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • bwanac
                          • 3354
                          Thanks Jordan. I dont know, I remember a while back when someone said the 'i' cover would not work with the eta head. I guess I can know now. :up:
