Stuck Accelerator
Tonight I went on a quick drive as I did some more work on the car, all was ok until I did a couple wot sprints and hit the clutch pedal when the throttle went wide open to the rev limiter :ohsnap:
So, I could duplicate it again and again by pressing the gas pedal all the way in, it seems like it doesn't release the pedal and it actually gets stuck in that position untill you hit the pedal again... fun.
Found a thread about this problem on e36 (http://forums.bimmerforums.com/forum...ck+accelerator) but nothing on e30.
What should I look at specifically, what should be replaced due to age etc ?
