Heater Problem
  • volgapower
    • 161
    Heater Problem
    i got a problem with a heater in 318i... it doesnot blow hot air, only cold...
    the both pipes in engine are always warm going in and out... also the sliders work, and in all 4 positions the cold air blovs... when i rotate the hot/cold handle, there is no response, cold satyes cold... what problem might be there?
  • AndrewBird
    The Mad Scientist
    • 11896
    You thermostat is probably stuck open. What does the temp gauge read when the car is fully warmed up?
    • AdamF 88iS
      • 2051
      Even if that was the case I doubt it would get cold enough to where you don't feel even luke warm air out of the heater.
      I'd say it's more likely to be some sort of blockage in the heater or a jammed heater valve. You could even have an issue with the big flap inside the dash box that directs the air through the heater core.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • volgapower
        • 161
        ok thanks... i'll try to fix it this weekend... i doubt that there is electic contact problem of the rotating hot/cold handle...
        • AndrewBird
          The Mad Scientist
          • 11896
          Depends on how cold it is outside.
