Head Studs
  • skat 325is
    • 296
    Head Studs
    Does anyone remeber the specs\meassurements of the Head Studs for the m20 head, used for a turbo application ?
    Thanks
  • skat 325is
    • 296
    *Bump*
    I need this info, i started to work on the car.
    Searched thru google and no info.
    All i know is someone on the other board posted this (i copied and paste)
    "Use Grade 12.8 10mmx1.5mm pitch x 150mm long socket head cap screws.
    Dip threads in engine oil and torque to 70-ft-lbs. "
    But those are for screws not studs, also what he meant by " pitch x 150mm" ??
    Thanks in advance.
    • Kavkazia
      • 394
      Hey man, good to know you started your project!
      Get Studs from this place, they have pretty good prices and Im about to order set next week probably.
      95' M3.
      90' 325i Turboed.
      87' 325eS Fixed.
