Crazy question....CABs....
  • RCWells
    • 3589
    I just had my new control arm bushings pressed into the lollipops and my question is this: How much off do the line/arrows have to be in order to cause a problem? One of them is spot on, the other is off juuuuust slightly, and I'm wondering how much a difference it will make? I don't want to install it if it's going to be a problem, but I don't want to take it back to the guy if it's not going to be an issue.
    Thanks
    [THE 501 club - Founding Member]
  • So Live
    • 2512
    Do you have centered ones or offset?
    i have the offset ones and one of mine isnt perfect. My castor numbers are .4 deg off. I can deal with that.
    -Chris
    • Mike325
      • Mar 2006
      • 3685
      You will be alright. If they were way off, then the cabs will rip and be wasted in a matter of a few good bumps.
      Originally posted by Kershaw
      • Mike325
        • Mar 2006
        • 3685
        Guess how long this bad boy lasted.....
        200 miles:o
        • e30tom
          • Mar 2006
          • 116
          200 miles:o
          Is that because they were waay off?
          • Mike325
            • Mar 2006
            • 3685
            Yep.
            • RCWells
              • 3589
              To clarify, they are the offset versions. It is a very minute amount, I would say even negligible. However, when dealing with geometry, a small amount here can equal a large amount elsewhere.
              I think it will be fine.
              Thanks for the replies anyway.
