Motor swap (87is into 91i)
  • svn2002s
    • Sep 2004
    • 479
    Planning a motor swap this long weekend. Is this a straight motor swap or do I need to bring some of the electronics from the donor car.
  • damith
    • 422
    motor swap
    there's much more info about this topic in e30tech also. u might want to chk it also.
    and GL with the swap
    [All the Bronzit haters]
    • porsche gt1
      • 237
      wow, never really heard of putting a M20 in place of a m50. Why this change?
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        91 325i still has the m20, unless the OP actually has an m50.
        • svn2002s
          • Sep 2004
          • 479
          I just got a 91 with a blown engine plus an 87 donor car. Just need to make sure that electronics, harness and other related shit that I don't know would be ok.
          • Rocla
            • 922
            If both cars have m20, why not keep all 91 injection pieces and just replace the engine?
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
            • redhatpat
              • Aug 2005
              • 656
              Agreed. This would be the simplest thing to do. The engine should be identical mechanically.
              • svn2002s
                • Sep 2004
                • 479
                That's the plan, I was just wandering anything on the electrical side.
                • Axxe
                  • Aug 2004
                  • 3355
                  You need to use the '91 wiring harness. ECU is interchangeable, pick the one that is a 173 :D.
                  Keep it slideways!!
                  • Keith M
                    • 2338
                    The main differences are: (this is based off my motor swap - 88 motor, 89 harness into an 87)
                    The FI on the 87 is wired directly from the main harness, On later models, they use the C171 plug between the harness and the injectors.
                    The plug for the O2 sensor is different.
                    There were several extra wires where the harness meets the ecu.
                    Keith
