318is vs. 325is rear diff question
  • jnbroadbent
    • Sep 2006
    • 33
    They are both LSD's correct? Are they the same?
    Getting ready for the swap. :up:
  • e30_kid89
    • Apr 2006
    • 489
    the 325is rear end is a large case diff that can take more power....the 318is features a small case diff..its said that the small case diff can take up to 210-ft/lbs of torque, but at the same time it said that the m20 has shreaded them apart in just a week but i guess you can find that out which one is true or false casue i have no idea...good luck with it
    • 2002maniac
      • 4260
      LSD was an option for the 318is
      • AdironRider
        • Dec 2004
        • 3491
        The 4.10 was indeed an option on the 318is. I would go large case just for peace of mind though and wouldnt trust a small case on an m20.
        Back to my roots
        • Jean
          • 18228
          Will a 318is/325is rear diff require a different drive shaft if installed into an early 318i or will be a direct swap ?
