Selector Rod Joint Question??
  • bmwcr89
    • 16
    Would this fit in my 1989 325i
    1990 325is
    instead of this
  • Spaz
    Crazy Canuck
    • 2276
    1990 325is
    instead of this
    Use the top one...thats the one i've alwasy replaced them with. The bottom on is from an e36 i believe.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • rs4pro3
      • 5808
      both styles are found on the e30's, the selector rod it self is different to match the two joints. So pick which one matches the rod you have, or find the rod to match the joint you want.
      85 325e 2.7 ITB'd stroker
      • 87-325ic
        • Apr 2006
        • 1198
        go to realoem.com and find out which one you really need.
        if you must.. get the M3 rubber shim instead of the felt pad on stock e30s.
        • bmwcr89
          • 16
          thanks that clears everything out
