Heylo all,
For some contorted reason other E30 folks have been able to check the emission fault codes on 1988 models, and I have not.
Apparently the Bentley and the (:curse: Haynes) say the CEL is supposed to flash any codes stored within about 3 seconds of the key being switched to the ON position. Mine doesn't do that. Nor does the pedal dance work either.
Checked the Bentley on the throttle switch. It is working correctly. >5volts between the outer terminals of the plug and the inner one. Tried the pedal dance but instead with the throttle thing on the throttle body. Nothing. Tried jumping the pins at the connector plug directly. Nothing.
Ugh, Houston, do we have a problem?
