Odd Question: Weight of S52 Crank
    Anyone have a number for the weight of the stock S52 (3.2) crank?
    And while we're at it, what about a knife-edged one?
    :) Thanks!
    -Prince
    Randall Prince
    http://www.rp1.us/ Used Cars
    22.9kg.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      Gesus H Christ...I was affraid of that...
      Anyone have any idea about the weight loss of knife-edging, etc?
      -Prince
      Randall Prince
        almost as much as oyou want to loose...
        I'm doing a relatively conservative knife edging on my 524td crank for my stroker project and it's going to shave about 8lbs off the crank. (td crank is 5lbs heavier than stock eta cast crank anyways) so I'll have an overall 3lbs weight savings...
        the more you take off, the longer to perform and balance... resulting in increased costs and possibly a weaker overall crank.
        Also, you don't want a crank that's TOO light since it would end up affecting your idle and torque...
          What's the stock weight of the td crank?
          -Prince
          Randall Prince
