MAF Conversion Question
  • T3rd Ferguson
    • Aug 2005
    • 3076
    Do any companies out there put out an MAF conversion other than Split Second? Preferably, cheaper than the SS kit. LMK
    Andy
    1989 Bronzit 325ia- Sold
    1988 Delphin 327i- Sold
    1995 Cosmos M3- Current
  • dirty30
    • 3121
    I think BMP sells one IIRC.
    • MrK
      • Jan 2006
      • 709
      Isn't the BMP one just a 'rebadged' Split Second MAF conversion with a healthy markup?
      This is your M20 on steroids:
      • NC325iC
        • Mar 2004
        • 6565
        i believe so
        • T3rd Ferguson
          • Aug 2005
          • 3076
          exactly.
          • T3rd Ferguson
            • Aug 2005
            • 3076
            My car has a new problem that im convinced is due to the AFM, which is completely shot. I dont see the point in spending 423 some odd dollars on a new AFM. I've switched it out with spares from parts cars etc, but the problem still exists on cold days.
            It seems when the motor warms up, that the throttle will completely cut out and i'll just coast. I hit the gas and NOTHING happens. the car backfires constantly when this happens.
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              not on topic, but andy, the stance of your car is fawesome
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                you sure it isn't starvation due to the fuel pump?
                Yours truly,
                Rich
                you kids get off my lawn.....
                • T3rd Ferguson
                  • Aug 2005
                  • 3076
                  well, im starting to think it may be one of the temperature sensors, or possibly even a timing problem. cause the backfiring can only mean a couple things, right?
                  • NC325iC
                    • Mar 2004
                    • 6565
                    if youve used more than one afm without fixing it i think its something else
                      Backfiring, in the absence of intake valve problems, is from a lean mixture or a timing problem. If the problem only exists when the engine is cold an intake leak is a possibility. In general a timing problem should be present whethter the engine is hot or cold.
